Too much sidewall for a new edge?
Old 10-19-2010, 04:44 PM
schmallz
schmallz's Avatar
I'm running 255/40 and 285/40 18s, no problems. But I have no idea how the offset on an 05+ wheel will effect a New Edge.
schmallz is offline
Old 10-19-2010, 05:57 PM
Norm Peterson
Norm Peterson's Avatar
It will move the wheel and tire about an inch inward. If you give me the wheel widths and offsets I can plot the difference up for you.
Norm
Norm Peterson is offline
Old 10-19-2010, 06:18 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
A good chart for off-sets is also located at:
RS Racing
Thanks, Norm
Jazzer
Jazzer The Cat is offline
Old 10-19-2010, 07:14 PM
Norm Peterson
Just so you know, I've got a spreadsheet that overlays plots of two different wheel/tire combinations, including offsets. The sidewalls are shown as curved and the section width increase as wheel width goes up is accounted for. There is a picture up in one of my albums that I used in some other thread. Takes under a minute to get a *.jpg ready for upload.
Norm
Old 10-22-2010, 11:53 PM
getafewlives
getafewlives's Avatar
I should probably clarify this, it is just the tires. NOT the rims that I will be buying. I will be putting the tires onto my 18" bullitts.
getafewlives is offline
Old 10-23-2010, 06:54 AM
Norm Peterson
285/40 tires do not belong on wheels less than 9.5" wide, according to the people who make them.
I'd cut you another half inch if your driving falls into straight line running and no harder than moderate cornering, so 9" with those restrictions.
On wheels narrower than 9" - only for a trailered show car.
Norm
Old 10-23-2010, 11:37 PM
Stang9946
Stang9946's Avatar
Norm
You could run Nitto 285s on a 9"...I wouldn't put any other 285 brand on a 9" wheel though.
Stang9946 is offline
Old 10-24-2010, 07:28 AM
Norm Peterson
9" is still half an inch under the listed minimum for at least the NT555 and NT555R models (which I just checked).
I'd cut you the same half inch of slack against that minimum, subject to the same straight line & moderate cornering driving restrictions.
It's tough to define how "hard" cornering is - particularly since your idea of "moderate cornering" or whatever very likely differs from mine. But if you're finding it pretty easy to steer the car using the throttle in any gear that's reasonable for the car speed - that's too hard for this kind of tire:wheel combination.
That particular tire size has more than enough load capacity, so as long as you maintain a streetable pressure (vs dragstrip) you should be OK from the standpoint of tire carcass heat buildup.
Norm
Tivo304
08-28-2023 12:19 PM
shrkbate
10-02-2015 08:25 PM
MusicCity615
09-27-2015 12:53 AM
09-23-2015 01:28 PM
Quick Reply: Too much sidewall for a new edge?
