Sponsored by:
Sponsored by:
Horrid Understeer
Old 11-15-2007, 06:11 PM
Yonco
Yonco's Avatar
Default RE: Horrid Understeer
It also depends on your driving and what you are doing. Your tires can only do so much. You cant turn, and brake(harder)at the same time, the tires will break loose from brakes, then skid, from the forces. Same with mashing the gas and steering( oversteer). I learned a lot from doing autocrosses. The car really doesnt turn, but i was always flooring it, then braking and turning, and the car would slide, if i slowed down before the corner, and accelerated through it, it would oversteer( better in my opinion) -Jon
Yonco is offline
Old 11-16-2007, 06:13 AM
LesteR723
LesteR723's Avatar
ORIGINAL: Yonco
I realize the tires can only handle so much but this vehicle and the way the chasis is set up and the suspension in the front was MENT to understeer. i was just looking for a way to correct it...
LesteR723 is offline
Old 11-16-2007, 07:39 AM
oi8achevy
oi8achevy's Avatar
jon your right on with the whoele driving technique thing. i used to autocross also when i first started dirving. the people were great and i learned ALOT about how to drive a car hard. i would recommend it to everyone to do it for a season. youll be amazed at how fast some people are with a stock to mildly built car. its cheap and alot of fun especially at the larger courses.
oi8achevy is offline
Old 11-16-2007, 05:56 PM
Yonco
Yonco's Avatar
Well, after my first time out i COMPLAINED that the car understeered, or i could floor it and make it oversteer, but lost a lot of time/tires) and i was looking for a way to correct the car, swaycars/lca's when i found its more of my driving style, i learned to drive the car, not upgrade the car so anyone can drive it, and my way was cheaper. -Jon
Yonco is offline
Old 11-17-2007, 09:49 AM
LesteR723
LesteR723's Avatar
i mean i have been driving the **** out of my car for over two year and i know the limits like the back of my head and i could make it go aroudn the course without any sign of under or oversteer, but i dont want that, i know that if i modified the car to NOT understeer as bad as the factory designed it to that i could take the course a lot faster and a lot harder.
Jskeezy84
09-08-2015 01:40 AM
ccwebb
08-11-2015 06:47 PM
NewMustang
01-27-2007 03:41 PM
eaglecatcher
12-20-2006 02:50 AM
Obsol3te
06-20-2004 02:35 AM
Quick Reply: Horrid Understeer
