Sponsored by:
Sponsored by:
Old 10-22-2015, 05:57 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
Print Wikipost
Replacing rear deck speakers
Old 02-03-2010, 11:30 AM
  #31
Rollin Thunder
Rollin Thunder's Avatar
Originally Posted by GTJT2010
ok I'm back lol................sad to report fastdew is right! no speakers...but fordeng.....I went into the engineering mode and is that cool, gauges go crazy, buzz, I love the fact you can bring up water temp in numbers, see real tach rpms, and the one test that lights up the whole gauge console with every warning light there is in car really lights her up, explain the fuel level what's telling us, then was another said date of manufacture?, but it's cool
if you get a vert model they are in that place since the top removes the rear deck.
also yes while there are only 6 visible speakers all the car companys are playing this stupid game that a tweeter even when attached to another speaker, counts as two speakers. So you get 8 speakers by....
2 speakers in the doors, which have tweeters, so theres 4 speakers total since ford plays this game, then the 2 on rear deck or on that panal if you have a vert. Really its 6 speakers. But all car companies do this now.
Rollin Thunder is offline
Old 02-03-2010, 11:48 AM
  #32
FastDEW
FastDEW's Avatar
Now that makes sense. I wasn't thinking of the vert. So the manual that FordEngineer posted is correct, for the vert. Got it now.....Thanks!
FastDEW is offline
Old 02-03-2010, 01:57 PM
  #33
WeinerDog
WeinerDog's Avatar
Yeah, that explains it. Thanks to Rollin Thunder and to FE for the info.
WeinerDog is offline
Old 01-26-2011, 09:28 PM
  #34
starbai
starbai's Avatar
Originally Posted by dominant1
Replacing the rear speakers is easy work . what i did was take out the rear deck cover cut 2 holes out so the new speakers wouldn't be covered like the factory ones. I mounted exact fit pioneer 3 ways to the metal deck lid. I bought 6x9 speaker grilles and mounted them over the holes i cut out in the speaker cover. That's all there is to it.
Got pics?
starbai is offline
Old 01-26-2011, 10:07 PM
  #35
starbai
starbai's Avatar
Originally Posted by USAF in Germany
I will document the rear deck speaker install with pics, since it doesn't seem to exist on the web. There will probably be a few pics of me cursing and pulling my hair. Just ignore those
Did you ever do this by any chance? Could certainly use this right now
starbai is offline
Old 01-29-2011, 10:26 AM
  #36
USAF in Germany
USAF in Germany's Avatar
I did! I believe I uoloaded the images on my Internet page, but if not, they are gone. My laptop I was using at the time went **** up. I'll check and post back. It was really pretty easy. The hardest part was pulling the rear side panels.
USAF in Germany is offline
Old 01-29-2011, 10:53 AM
  #37
starbai
starbai's Avatar
excellent I would appreciate that!!!
starbai is offline
Old 01-29-2011, 07:56 PM
  #38
JWButler14
JWButler14's Avatar
dont do what dominant did it will look like garbage. if you just remove the door sills (on both sides), then take out the seats (bottom first), then the rear side panels even the panels around the quarter windows u will be able to take the rear decklid panel out without BENDING it then you cant remove the 7mm bolts holding the speakers in and replace them and dont worry if you cant get all four bolts back in because three will hold just fine but if you can put some velcro or something else up under the corner that wont have the bolt in it to keep it from rattling. i have done this to two 2010 mustangs and also im a installer at car stereo/video store so i know what im talking about
JWButler14 is offline
Old 01-30-2011, 04:19 AM
  #39
USAF in Germany
+1. That's exactly how I did it. After removing the sills, I took the rear bottom seat cushions out, folded the backs down, and took the screws out holding the side panels out. Then carefully slid the side panels forward, allowing me to then pull the deck panel forward. I installed the speakers and put it all back together. [ QUOTE=JWButler14;7395238]dont do what dominant did it will look like garbage. if you just remove the door sills (on both sides), then take out the seats (bottom first), then the rear side panels even the panels around the quarter windows u will be able to take the rear decklid panel out without BENDING it then you cant remove the 7mm bolts holding the speakers in and replace them and dont worry if you cant get all four bolts back in because three will hold just fine but if you can put some velcro or something else up under the corner that wont have the bolt in it to keep it from rattling. i have done this to two 2010 mustangs and also im a installer at car stereo/video store so i know what im talking about[/QUOTE]
Old 01-30-2011, 09:41 PM
  #40
jcieutat
jcieutat's Avatar
Damnit, now I want to replace the stock speakers in my car!!!!!!!!!!!
jcieutat is offline
Chris07GT
09-01-2015 07:11 PM
bikerdoc
08-25-2015 06:46 AM
Tyoung68
08-25-2015 04:31 AM
kdryan
08-21-2015 04:01 PM
69FB
08-18-2015 08:50 PM
Quick Reply: Replacing rear deck speakers
