Sponsored by:
Sponsored by:
First run on a drag strip coming up help!
Old 02-14-2011, 03:20 PM
big red one
big red one's Avatar
Thanks for all the tip's fella's its only for fun like i say but then.......
Ill try the 2500 launch and im on the P, Zero's like the idea of deflating the tires
big red one is offline
Old 02-14-2011, 03:57 PM
daredevil95
daredevil95's Avatar
You didn't mention if you have any mods.....lowering the tire pressure and removing the airfilter from the air box helps. Don't forget to shut the traction control!!
daredevil95 is offline
Old 02-15-2011, 10:38 AM
big red one
No mods the car is standard with the brembo pack
Old 02-15-2011, 11:13 AM
Norm Peterson
Norm Peterson's Avatar
Go into it with the attitude that your first run (at least) will be a "throw-away" while you settle down. Maybe think of it in terms of two runs for time with two practice runs first.
Norm
Norm Peterson is offline
Old 02-15-2011, 01:56 PM
Dewyrussler
Dewyrussler's Avatar
Sounds like you've gotten some good advice. Mine would be to drive out to a secluded area and do a few practice launches to see how it feels. That will help you figure out how to best reduce wheel spin. Also, remember the basics like weight reduction (remove all the crap you don't need from the trunk while you make your passes). I see you have Brembos so you don't have a spare to remove...but you can take out the fix-a-flat and anthing else extra. Also, run your gas tank down to about an eighth of a tank (at about 6lbs per gallon, keeping your tank low can really make a difference) .
Every little bit helps! Good luck and have fun!!!
Dewyrussler is offline
SterlingStunner
5.0L V8 Technical Discussions
09-04-2015 06:28 AM
gus_vb
08-29-2015 11:35 PM
1987gt40ttopt
08-28-2015 10:49 PM
labudski
08-24-2015 07:23 AM
Jacob4589
08-08-2015 11:00 AM
Quick Reply: First run on a drag strip coming up help!
