Air/Fuel Ratio - Is this about right?
Hi Guys,
I just got everything together on my car. Yes, Finally!! I have the Brenspeed Blower Cams, the Roush M90 and the VMP500 HP Kit. I asked VMP to tune for the cams.
My AFR gauage is showing about 13.5 at idle and is running around 14.4 to 14.7 while driving steady state.
If I floor the car, it shows 7 PSI of boost and the AFR is right about 10.5 steady.
Sometimes the car runs more around 14.3 at idle, but then it kind of loads up a bit and drops to 13.5 again, however I expected that given I am running the blower detroit rocker cams and idle is set at 650 RPM.
Anyway, what do you guys think? Are my AFR's in about the right place?
I only see above 14.7 if I am off the throttle and if I am all the way off and the engine is slowing against the car it will jump to 20, but I figure the injectors are probably off then anyway.
What do you guys think? The throttle response is perfect!
Hi Guys,
uberstang1
09-20-2015 06:42 PM
09-03-2015 07:14 PM
