351 Mustang
gt40 heads ?
Old 07-06-2014, 06:59 AM
swanny
swanny's Avatar
Default gt40 heads ?
i have a 351 blocked bored 30 over i want to put gt 40 heads with 1.7 crane cams roller rockers and a big comp cams am i goin to have clerance problems
swanny is offline
Old 07-06-2014, 12:27 PM
bluebeastsrt
bluebeastsrt's Avatar
Sure your going to have some clearance problems. The engine will most like sit about 1.5 inches higher than a 302. Your talking a 9.5 deck height VS. an 8.2! You'll most likely run into header clearance issues. But it's a common swap. I think you'll want to change the motor mounts. I also think a oil pan swap is needed. There's probably a ton of guys that have done the swap in this section that can answer the question but I don't think you just drop in a 351. Good luck.
bluebeastsrt is offline
Old 07-22-2014, 02:10 AM
84CopperGT
84CopperGT's Avatar
Do you mean piston to valve clearance or engine clearance? Because those are totally different things. I would think you would need some big valve reliefs in the pistons for that cam/head/rocker combo.
84CopperGT is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
mustangheaven
10-07-2015 10:23 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: gt40 heads ?
