Brake Fluid Change
Old 03-14-2015, 06:24 PM
teetertotter
teetertotter's Avatar
Default Brake Fluid Change
I heard on Motor Week this morning that it is a good idea to change the brake fluid every 2 years due to water build up. I thought everything is pretty much sealed. Just my comment. I'll probably call my mechanic and get his input. He's an honest fellow and works on mine when required. Maybe a preventative maintenance thing?
teetertotter is offline
Old 03-15-2015, 03:06 AM
jimkaray
jimkaray's Avatar
I beleive its since the use of ABS that this has become a more of an issue. The ABS unit is sensitive to the effects of degraded fluid that moisture causes. Even though it is a sealed system brake fluid attracts moisture so it builds up water over time. For that reason its not good to keep open bottles of brake fluid around for very long. I buy the small bottles for this reason unless I'm doing a planned flush.
jimkaray is offline
Old 03-15-2015, 09:32 AM
teetertotter
Default Flush and Change Brake Fluid
I am going to put this and the new SUV on the 2 year cycle to flush and change brake fluid. I guess you might call it preventative maintenance. You learn something new every day!
Tivo304
08-28-2023 12:19 PM
2007StangV6
01-28-2016 06:09 PM
musnicki
09-23-2015 07:11 AM
IronRaptor
09-09-2015 08:10 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Brake Fluid Change
