Wheel Alignment?? $$
RE: Wheel Alignment?? $$
ORIGINAL: Krusher
dispute the charge and file a complaint with your local chamber of commerce... that garage needs to be shut down... oh and if ANYONE wants to drill ANYTHING that affects your alignment tell them to go to hell... that's just not the way it's done.
thats totally bogus
thank god you stood up
and ya, there should never be a time when you need to get the rear wheels alligned.....
ORIGINAL: sandcracker21
[/font]+1000000
thats totally bogus
[/font]+1000000
thats totally bogus
I need your email address since I can't put this pdf up here on the forums. I am going to send you an exact printout from the service manual for your vehicle.
So... unless you've been in an accident with the vehicle... it clearly shows that you can have your vehicle aligned.
then it depends on your ride height. If your ride height is off then there is a possibility that you will need larger adjustment plates in order to align the front suspension...
I have H&R Sports with about a 1.8-2" drop in the front, my alingnment was wayyyyyyyyyyyyyyyyy off, i had to get a set of CC plates, i went with Steeda, chances are if you get springs your gonna need plates
If you have aftermarket springs... its your fault dude.
He probably was bitching about ford because he wasnt aware you had aftermarket springs. You should have bought caster/camber plates with the springs. He has to drill to beable to adjust the camber angles to a certain degree.... the stock ones are not made for a big extreme.
mungodrums
09-28-2015 10:54 PM
