squeeling noise
squeeling noise
Alright,
I am new to this site but that is besides the point. I drive a 1999 ford mustang gt 4.6with 70,000 miles on it.
It is yellow, with a black top convertible, and it is a standard.I will have pictures posted as soon asI can.
I am having a slight problem. When I press the clutch in it sounds like there is a rat running on a wheel in my engine.
But when i let off the clutch it does not happen. It usually takes about 5 seconds until you hear the sound.
I thought it was a belt at first, but once again it only happens when I press in the clutch.
RE: squeeling noise
ORIGINAL: Rollin88
Sweet that is what i thought. Not so sweet because i don't want to buy one. haha. any opinions for a good one?
You should do the same, once you go through the hassel of dropping the tranny, replace the pilot bushing, TO bearing, clutch and pressure plate if needed, and inspect the flywheel, have it turned if needed. I replaced mine with Aluminium. *grin*
KingRando
10-02-2015 08:06 AM
Ghost_Conscience
09-23-2015 02:17 PM
ccdguy
09-19-2015 05:20 PM
