Procharger / Lightning MAF
Old 03-05-2008, 07:47 PM
jlw2387
jlw2387's Avatar
Default Procharger / Lightning MAF
For all yall runniing a Procharger and a Lightning MAF, what did you do for the rubber hose directly upstream of the MAF. The piece that was included from Procharger doesnt fit. So can I just goto Pep Boys and get a 4" to 3" adapter hose?
jlw2387 is offline
Old 03-06-2008, 08:17 AM
Ryan86272
Ryan86272's Avatar
Default RE: Procharger / Lightning MAF
Justin at VMP Advised me Against Using the Lightning MAF.... Something like to big to to funnel down or something.... Cant member, But ALOT of Stangs do use them so i guess its just tuner Preference
Ryan86272 is offline
Old 03-06-2008, 08:59 AM
Chris98Gt
Chris98Gt's Avatar
Yea just find a 4" to 3" and you should be fine. Try to get a gently sloped one though, I had a plumbing pipe reducer with a sharp angle and at high rpm shifts it would blow it off before the bov let all the boost go.
Chris98Gt is offline
Old 03-06-2008, 10:24 AM
Sxynerd
Sxynerd's Avatar
Just be carefull on cold night racing and pushing it to the limit.
Sxynerd is offline
Old 03-06-2008, 05:58 PM
Obsequious1
Obsequious1's Avatar
I found a 3 to 4in the plumbing section @ Home Depot. Its a blue colored urethane piece. It worked great.
Obsequious1 is offline
Old 03-06-2008, 06:12 PM
contentsunderpressur
contentsunderpressur's Avatar
Read all below please. It'll let you know all you need to know about maf with a blower.
Please read my posts here concerning MAF and BOV proper placement:[/align][/align]http://www.modularpowerhouse.com/for...p;postcount=45[/align][/align]http://www.modularpowerhouse.com/for...p;postcount=48[/align][/align]It would be better to switch to a blow-thru, yes. A proper blow-thru setup, like I described above is always better. You want the pcm to be able to see the actual aircharge entering into the engine, as close to the engine as possible (but not so close where you would get backwash from the intake/TB area).[/align][/align]You definitely do not want the 90mm in a 3" tubing, and you really don't want the 90mm in a blow-thru in the first place. Here is the MAF housing and sensor that I recommend:[/align][/align]http://www.vmptuning.com/store/index.php?p=product&id=234&parent=99 [/align][/align]That utilizes a slot-style sensor (ala '05+ Mustang, '04+ F150, '08 Corvette, etc.). That is absolutely the #1 sensor on the market, and the best sensor on the market for a blow-thru application. It is very easy to tune, and very repeatable, and is good to 650 rwhp Actual in a 3" blow-thru application. I have tuned approx. 12 or so vehicles with that in the last 6 months.[/align][/align]
contentsunderpressur is offline
jwog666
12-27-2021 08:09 PM
articman
06-21-2018 11:45 PM
Granatelli Sales
03-21-2016 06:16 PM
09-18-2015 06:49 PM
09-18-2015 12:25 PM
Quick Reply: Procharger / Lightning MAF
