A/C problems-need help
Old 08-19-2008, 01:19 PM
brock_07
brock_07's Avatar
Default A/C problems-need help
last nite on my way home i was runnin my a/c and i looked over in the passenger floor and there is a huge puddle of water, so i pull over and i pull down the carpet and water is runnin out really bad i cut the a/c off and it slows down for a minute then stops runnin out...what could this problem be?
brock_07 is offline
Old 08-19-2008, 01:55 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
The drain tube for the evaporator housing is clogged or has become disconnected...
cliffyk is offline
Old 08-19-2008, 03:58 PM
brock_07
brock_07's Avatar
how do i fix that when i put my hand up there was a piece of plastic that was broke in half
brock_07 is offline
Old 08-19-2008, 04:22 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
The exact nature of fix depends greatly upon what pice of plastic is broken.
If it's the evaporator/blower housing that's split there may be some innovative in-situ repair that can be done with epoxy/resin/fibreglass cloth; if that cannot be done that you may need to replace the entire unit which involves pulling the entire dash...
Wish I had better news, any chance you could get some photos of what is broken?
cliffyk is offline
Old 08-19-2008, 05:48 PM
Brute03
Brute03's Avatar
does the water smell like coolant?
Brute03 is offline
Old 08-19-2008, 05:57 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
A leaking heater core is another possibility (it also means yanking the dash, etc.), however the OP said it slowed when he shut down the AC...
cliffyk is offline
Old 08-20-2008, 12:35 AM
brock_07
brock_07's Avatar
well ive been thinkin about doin an a/c delete anyways....so i guess now would be a good time to go ahead and do that since its broke
brock_07 is offline
vargas
06-17-2017 12:17 PM
69Volunteer
09-30-2015 10:39 AM
SteelerNation82
09-16-2015 07:11 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: A/C problems-need help
