intake question?
Old 09-23-2009, 06:27 PM
lawdog205
lawdog205's Avatar
Default intake question?
Where does the stock intake fall short..will 15 lbs of boost be a no no?
Also..has anyone tried the BBK 78mm throttle body plenum combo?
Thanks
lawdog205 is offline
Old 09-23-2009, 06:42 PM
grogan
grogan's Avatar
14 psi is the maximum amount of boost to run on the stock block, im assuming that would be the same for the stock plastic manifold
grogan is offline
Old 09-23-2009, 06:53 PM
lawdog205
lawdog205's Avatar
Got the block covered...I would guess you are right about the intake as well..
Anyone else?
Anyone have the Typhoon intake?
Thanks
Old 09-24-2009, 02:11 PM
grogan
grogan's Avatar
im running the typhoon intake. ive gotten about 3k tied into it to actually get it working properly. i wouldnt recommend it.
grogan is offline
Tivo304
08-28-2023 12:19 PM
Luke9222
10-22-2015 11:55 PM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: intake question?
