sct tuner problem
Old 01-27-2010, 08:09 PM
SilverGT03
SilverGT03's Avatar
Default sct tuner problem
When I plug my X3 into my car the tuner loads up and gives me the main menu. From there I went to program vehicle and then to strategy tune. When I push the select button it says error strategy tune not supported. Any ideas? It says that every tuner comes with 3 preloaded tunes. Also where would I go to change my axle ratio?
SilverGT03 is offline
Old 01-27-2010, 09:49 PM
SilverGT03
SilverGT03's Avatar
So, I figured out why the tuner did not have any tunes pre-programmed into it. When updating the tuner you need to select tune revision and download the file. My problem now, is after I download the update software and firmware there is no option to download the tune revision under the X3 tuner. It is however available for all of the other tuners like the livewire, etc... Anyone have any knowledge on why this may be happening?
Old 01-28-2010, 07:11 AM
smitty2919
smitty2919's Avatar
i woud just call/contact SCT directly....
smitty2919 is offline
Old 01-28-2010, 01:15 PM
ChalknCover
Sgt. Killjoy
ChalknCover's Avatar
You may wanna check out this section for tuner help. You could see if Mike from Diablo can identify your issue or may have info to lead you in the right direction.
ChalknCover is offline
Jb145700
08-21-2022 06:37 AM
articman
06-21-2018 11:45 PM
04stangman
09-17-2015 01:45 PM
ernesto-619
09-10-2015 01:32 AM
Quick Reply: sct tuner problem
