96 cobra overheating???? any suggestions or ideas??
Old 08-01-2005, 12:11 AM
JoHnNy sAvAgE
JoHnNy sAvAgE's Avatar
Default 96 cobra overheating???? any suggestions or ideas??
I got a 96 cobra and it seems to be running a bit hot. I've had a 01 gt and it used to at the most stay in the middle of the temperature gauge. The cobra goes over that and sometimes seems that it almost goes into the hot. I took it to the dealership and I was told that it was normal for the cobras to run that hot... Any one here got a cobra?? does yours run that hot??? I've already changed the thermostat, the fan sensor, and had the coolant flushed. Thanks guys
JoHnNy sAvAgE is offline
Old 08-01-2005, 05:26 AM
tcuallstar
tcuallstar's Avatar
Default RE: 96 cobra overheating???? any suggestions or ideas??
those things were gonna be my guess, the only thing i could reccomend is to get a lower temp thermostat like a 180 or 160, that way the car starts cooling earlier so you dont over heat. also it could have something to do with the oil circulation, mabye the pump? whats your oil pressure look like? dont use that as concrete info, its just a guess. my 03 gt runs a little to the left of the middle of the thermostat gauge when shes warmed up if that helps
tcuallstar is offline
Old 08-01-2005, 03:25 PM
JoHnNy sAvAgE
any one else????
Old 08-01-2005, 03:31 PM
mustang_montana
mustang_montana's Avatar
its summer time, use your ac a lot? thatll doit and that aint gonna hurt. also if you get on the gas a lot that sometimes spikes the temp a bit for me
mustang_montana is offline
CarlessAndy
CarlessAndy's Avatar
How close to hot are you talkin? My cobra goes to the right somewhat when its hot out but nothing spectacular.
CarlessAndy is offline
Old 08-01-2005, 04:50 PM
JoHnNy sAvAgE
I would say at hottest between the M and the A (where it spells out normal on the gauge) I am worrying for nothing?? To me it seems a little hot... Thanks for the help guys
Old 08-01-2005, 08:07 PM
uberstang1
Chupacabra
uberstang1's Avatar
I had a 97 cobra and it had a similiar problem except it would be fine one second then spike into red and overheat and it turned out to be a head gasket.
uberstang1 is offline
Old 08-01-2005, 09:23 PM
BCisme
BCisme's Avatar
the 96 cobras had cooling problems. ford makes a kit with higher output fans to solve the problem. i'm not sure where to find it though.
BCisme is offline
Old 08-02-2005, 01:35 AM
JoHnNy sAvAgE
I appreciate the help fellas!!!
Old 08-04-2005, 07:07 PM
Marine0311
Marine0311's Avatar
Do you have any mods to it? I know pulleys will bad on your cooling system as it slows the water pump down. Just a thought.
Marine0311 is offline
11-10-2015 11:39 AM
TorinoCobra070
SVT Forums
09-18-2015 10:34 AM
MusicCity615
09-12-2015 07:05 AM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: 96 cobra overheating???? any suggestions or ideas??
