Not many 2V with combos that would last any significant amount of time. I keep a stock head on display at the shop from a motor like this, you can dance the exhaust valves around the exhaust guides are so worn out, the clearance went from 004 stock to 030 give or take in under 30,000 miles.
You can do 400RWHP all day long, but getting to the 500RWHP point pretty much the entire motor needs to be tweeked some if you want it to last.
Hmm, didn't know that. Is that a typical result you see from the exhaust valve at that power level? Can't say that I've heard of people having that issue.
2V wear out the guides, 4V drop the seats completely (over 20lbs of boost).
You see it over and over enough you add 2+2 and get 4 sometimes.
There is only one aftermarket head for this motor and it comes already set up if you get the higher spring seat version.
no there are a couple of them. trickflow and patriot are two makers of cylinder heads that i know about. i know that trickflow is the only head that just isnt a ported version of the PI heads though
All of the aftermarket cylinder heads available for these cars with the exception of the trick flows are just ported PI heads. Ford racing offered the SVO head for a short time, but it's no longer available.
The trick flow is the only true aftermarket head since the others are just modified stock castings.
