I have a 5th gear problem!
Old 08-10-2012, 01:00 PM
theredone
theredone's Avatar
Default I have a 5th gear problem!
I know I should probably post in the introduction forums first but I'd really like to figure this out!
I have a 99 gt and I have problems with my 5th gear. while cruising it takes me two tries to get it into gear but on the second try it goes in very smoothly. If im stepping on it, it takes me quite a few tries to get it into gear. If I am at a stand still, it will go into gear just fine. Or if I go from 5th gear into 4th gear then sometimes I can **** back into 5th perfectly fine while driving.
Anyone know what this could possibly be??
Matt.
theredone is offline
Old 08-10-2012, 01:01 PM
theredone
theredone's Avatar
And I meant to say shift where the stars are at in my post..
Old 08-10-2012, 01:04 PM
Doyon
Doyon's Avatar
I have problems getting into 5th gear my myself, I created a thread a while back and most people told me it was my Synchros. But I'd wait until someone who knows what they are talking about come in here and give some advice !
Doyon is offline
Old 08-10-2012, 01:05 PM
EddyG
EddyG's Avatar
I'm pretty sure it's your syncros not lining up in 5th.
EddyG is offline
Old 08-10-2012, 01:10 PM
theredone
theredone's Avatar
I did a quick look on the internet and didn't find jack for syncro's, so I headed over to ebay and found these (link below)
http://www.ebay.com/itm/SY-149-Syncr...#ht_2568wt_982
Are these what I need? Has anyone ever took this to a shop and had it done? How much did it cost?
Old 08-10-2012, 01:12 PM
theredone
theredone's Avatar
Actually just found another kit but just for 5th gear, would this be what I need?
http://www.ebay.com/itm/T5-Transmiss...#ht_2214wt_982
Old 08-10-2012, 01:44 PM
1998Slow 'Stang
1998Slow 'Stang's Avatar
A T5 is worlds different from your T45.
But the t45 in your car is getting past it's prime...could be time for a rebuild....
1998Slow 'Stang is offline
Old 08-10-2012, 01:54 PM
theredone
theredone's Avatar
Would anyone know how much a shop would charge to pull the tranny out and put all of the parts in? (if I bought all the parts else where)
Old 08-10-2012, 04:23 PM
EddyG
EddyG's Avatar
I would say a shop would charge around 300-500 bucks. Just go get a used t-45 instead. It would be a lot easier.
If your grinding going into 5th the syncro needs to be replaced cause its shot.
If it just won't go in. The syncro needs to be re aligned.
It's not even worth it to just replace 1 syncro. The 300-500 is just installation that's not including part you don't know about that may be broke in the trans, trans fluid, seals, just a lot of stuff you may not think about.
EddyG is offline
Old 08-10-2012, 04:31 PM
1998Slow 'Stang
Good luck finding a shop that will put your parts in a transmission that you want rebuilt...and if they do the work they more than likely will not warrenty it.
articman
06-21-2018 11:45 PM
musnicki
09-23-2015 07:11 AM
Pyrate Dave
09-10-2015 07:30 PM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: I have a 5th gear problem!
