Intake leak
Old 11-29-2012, 01:09 PM
97bluethundergt
97bluethundergt's Avatar
Default Intake leak
I have a 97 gt and its been leaking coolant for sometime now so about a week ago i put a brand new dorman intake manifold in to try and fix the problem it didnt what else should i be looking for as a cause for this
97bluethundergt is offline
Old 11-29-2012, 05:19 PM
uberstang1
Chupacabra
uberstang1's Avatar
Confirm that the manifold is actually the sorce of the leak.
uberstang1 is offline
Old 11-30-2012, 08:55 AM
97bluethundergt
It cant be the manifold my dad says it might be a freeze plug in the back of the engine. I just was wondering if theres anything else that could cause a leak close to the back of the engine on the passengers side
Old 11-30-2012, 11:25 AM
Stevo86
Stevo86's Avatar
Is it wet above or below the head?
Stevo86 is offline
Old 11-30-2012, 12:50 PM
uberstang1
Chupacabra
uberstang1's Avatar
possibly head/head gasket, theres also heater core lines there that can leak. or soft plug
Old 12-01-2012, 07:10 AM
petrock
petrock's Avatar
Put down the wrench & stop guessing... Rent a radiator pressure tester from your local autoparts store, hook it up to the radiator when the motor is cold, pump it up to the same PSI listed on the radiator cap and listen for any hissing noises and look for any drips. Shouldn't be too hard to track down. Good luck...
petrock is offline
Vrooom
02-21-2016 05:25 PM
bconboy
09-24-2015 01:55 PM
04stangman
09-17-2015 01:45 PM
MusicCity615
09-12-2015 07:05 AM
Quick Reply: Intake leak
