A/C Cooling Issue
A/C Cooling Issue
Hey Guys,
My 2000 GT A/C stopped cooling on the way home yesterday. I've checked a few thing but haven't had the time to dive into it. My dash light also stopped working at the same time.
I checked and found that the compressor clutch is not engaging. I've checked the refrigerant level and that's good. I have also checked fuses and tried to jump the low pressure switch and it still wont kick on.
That's about all I have had time to check. Its weird that my dash lights go out and the a/c stopped cooling at the same time.
Does anyone have any advice on what to check next? Any way these two are connected? Could i have possibly missed a fuse? Could it be a bad CCRM?
Thanks in advance.
Thanks in advance.
It sounds like a blown fuse (or 2) to me. It has to be electrical related and not a problem with your A/C since your dash lights also went out.
You checked the fuses to those circuits?
Any other symptoms come up in the last day or so?
You could try jumping the relay(not the pressure switch) to the compressor and see if it comes on.
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
