Coolant drainage locations
Hey Techs,
In need of your help. I have a 99 Mustang GT. I want to do a complete drainage and replacement of the coolant. I know there is one drainage location down at the bottom of the radiator (passenger side) but I have also learned that I need to drain the coolant from the engine block too. Apparently there are two bolts (not sure if they are bolts or petcocks) under the bottom of the engine block. One on each side of the block. I checked but I just can't find these two bolts. Can someone please point me to the exact location of these two bolts. Also, If you could post a pic or two, I would really appreciate it.
Thanks,
Thanks,
I agree with the above, simply undo the bottom hose
But to answer your question i put together a write up MANY years ago about installing gauges in a 99-04 GT.
You can find pics of the drain on the side in there
https://mustangforums.com/forum/4-6l...-new-edge.html
