why not 3.90's?
Old 12-17-2005, 01:55 AM
JoeyD
JoeyD's Avatar
Default RE: why not 3.90's?
Hi fast,
Yes reason many turn away from 3.90's is due to the simple fact that FRRP doesn't make that ratio.
PERSONALLY I would rec. FRRP 4.10's for you. if you have a manny tranny.
I assume you do? but I dont see a SHORT THROW shifter listed in your mod list.
So if you do, I would get 4.10's, big DR's (BFGs are awsome) in the back, and LC arms... short throw shifter ---FOR NOW.
if you have an auto... I would get 4.30's, big DR's, and LC arms... stall converter ---FOR NOW.
you will see the times drop with these mods for sure, good choice.
JoeyD is offline
Old 12-17-2005, 02:58 AM
mustang_montana
mustang_montana's Avatar
i got 3.90s cause i got a twins crew blower going on VERY SOON so i wanted inbetween 3.73s and 4.10s. if the traction is too bad with the 3.90s ill just deal with it.
mustang_montana is offline
Old 12-17-2005, 04:14 AM
nanaki
Retired MF Moderator
nanaki's Avatar
ORIGINAL: mustang_montana
hahaha! IF it's too bad? traction is horrible with a KB or even just the eaton on a cobra with 3.55s. you're doomed! [:-]
nanaki is offline
Old 12-17-2005, 05:37 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
ORIGINAL: freeunit
Why doesnt anyone ever get 3.90's? is it because if your going to get those you might as well just get 4.10's? I think i have a better chance at getting 3.90's than 4.10's because my dad had 4.11's in his chevelle and hated them so i think he might let me get 3.90's is that a bad idea? Any help is appreciated...
Thanks Brian
Your dad did'nt have an overdrive trans in his Chevelle, this is old school thinking at it's best, you cannot compare the two cars like that, there are too many differances. If you have traction problems then you need to dial in the suspension and get better tires.
ORIGINAL: nanaki
hahaha.. get some DRs and you MIGHT. control arms aren't going to give you better traction, they'll help with the hippity hop when you're changing gears though.
Actually they can. Adjustible control arms can let you set up your instant center and pinion angle which can help plant the tires (or if done wrong, unload them)
JD1969 is offline
Old 12-17-2005, 06:12 PM
mustangman02232
mustangman02232's Avatar
the chevelle was a classic, the transmisions all have different gear ratios as well as rear end ratios, if your staying N/A, foxes do 3.73s, SN-95s do 4.10s, and 05-06s (not sure on platform number, but i think its DEW-90) do 4.30s,
mustangman02232 is offline
GimpyHSHS
08-29-2015 06:30 PM
DILO2001GT
10-13-2005 12:01 PM
BicketyBam
20
07-02-2005 01:32 PM
BicketyBam
06-18-2005 01:57 PM
madmojo20
11-21-2003 01:40 PM
Quick Reply: why not 3.90's?
