Rearend Noises
Old 02-17-2009, 08:36 PM
Snakebyte94
Snakebyte94's Avatar
Default Rearend Noises
Hi guy's, I have an 07 Mustang GT. I have been having a problem getting my rearend to ride right. The rear was riding fine when it was in the stock setup. w/3:55 gears.
I then had a local shop put the Torsen T2 in it. The gears started to make noise. They took the rear apart again and replaced the pinion bearing. That quite it down alittle. It was not so loud that I had to redo it. So I let it go for a year. Then it started to make alot of noise. So I took it back today the shop replaced the gears, carrier bearings, and pinion bearings. It's still making noises. I don't know if there is a problem with the Torsen or The rearend housing. Anybody have ever had this problem????
Snakebyte94 is offline
Old 02-18-2009, 07:49 PM
moosestang
moosestang's Avatar
It would help if you described the noise and when it's happening.
moosestang is offline
Old 03-01-2009, 11:07 AM
Snakebyte94
Well I found the problem with the rear end. It turns out that the Torsen T2 I had put in was bad from day one. After doing the rear end 6 times and three differant gear sets I am back to my stock rear end. And lesson cost me almost $2000. Thanks
Old 03-01-2009, 01:38 PM
Stkjock
Retired Mod
Stkjock's Avatar
well that sucks, most aftermarket rears will make more noise then stock, will they replace the rear under warranty?
Stkjock is offline
Old 03-02-2009, 03:34 PM
hardcore302
hardcore302's Avatar
Taco Bell/White Castle will do that. Delicious, yes. Happy stomach, no.
On a serious note, if it whines, I think there is a TSB. Don't know it off-hand.
hardcore302 is offline
bjdutch2005
03-24-2017 03:38 AM
KingRando
10-02-2015 08:06 AM
Ghost_Conscience
09-23-2015 02:17 PM
67LimeCoupe
09-21-2015 06:34 PM
Quick Reply: Rearend Noises
