Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-06-2009, 05:25 PM   #1
will7650
Vehicle: 2005 ford mustang gt
Send a message via Yahoo to will7650
Default How to go about forging the bottom end?
So I plan to super charge my s197. im gonna start by running a KB stage 1 intercooled at 8-9 psi and tune it to around 450 rwhp so the stock block and internal will hold up until i can forge them.
So after I do that, Whats the best, most cost efficient way to go about forging the bootm end. Do I buy a seperate forged short block already assembled with forged pistons, crank and rods? Do I reuse my aluminum block and have a shop install forged internalls? Around how much does something like this cost parts and labor wise?
will7650 is offline   Reply With Quote
Old 10-07-2009, 01:46 PM   #2
impulse GT
Vehicle: 2005 Mustang GT
First, go Whipple instead of KB. WAAAY better product and way better company. Second, a forged shortblock is going to cost a bit more but it will save you weeks in down time if you end up using your own engine. Either way expect to pay between $3500 to $4500 for just the bottom end or short block then another $1200 to $1600 for a shop like ours to install it and swap over your stock heads. And thats if you decide to keep the heads stock and not do cams at the same time.
I make 515rwhp on my stock motor and haven't blow it yet for almost 30,000 miles. How much more power do you need?
eric@impulsecars.com
impulse GT is offline   Reply With Quote
Old 10-07-2009, 02:35 PM   #3
cummins cowboy
Vehicle: 07 gt
I would like to know what specifically is better about a whipple than a KB blower, having done some research myself the KB is the best setup especially for a guy looking to upgrade later and the reason is, the KB is a 2.6l blower the competition is a 2.3l that means its gonna support more power, which means you don't have to change out the blower when you wanna up the boost after your bottom end is forged. the KB makes the most sense to me for the money. because its got the bigger blower
cummins cowboy is offline   Reply With Quote
Old 10-07-2009, 02:58 PM   #4
Stkjock
Street Strip Sheriff
2006 Ford Mustang
Stkjock's Avatar
Vehicle: 2006 Mustang GT
if your paying a shop to do all the work, it's not gonna be much different to have your motor built then to buy a built S/B
IMO buy a built S/B and then sell the stock S/B
either the KB or Whipple will support the power you'll make - if looking for 700+ then different story
__________________
Tngstn 06GT-5 spd -Vortech HO S/C-Tuned by Realspeed Auto
You can never have too much power, just not enough traction.
11.867 @ 119.35
Stkjock is online now   Reply With Quote
Old 10-07-2009, 03:25 PM   #5
mac10chap
mac10chap's Avatar
who cares what kind of blower he wants to go with, let him make his decision for his car, thats why all those companies are in business; b/c different people see different things in each set up...now to answer your question about the forged internals..
Stkjock said it best. Get you a forged short block and maybe even try to pick up a set of used heads to port and polish. Then you can do an engine swap, minimize down time and make up some of that money by selling your stock engine to someone else.
__________________
Procharged 10PSI H.O. Intercooled
498whp/445wtq
For sale: plasma booster ignition
Quote:
Red Turbo Integra
That's the plan. The only thing that sucks is I have a dentist apointment in the morning. Hopefully all the numbing sh1t wears off quick so I don't look like a retard drooling on myself.
mac10chap is offline   Reply With Quote
Old 10-07-2009, 05:05 PM   #6
will7650
This does make sense and the way im probably gonna do it thanks. Im not a big mechanic and never built an engine before so an already built short block would be alot easier. Ive also been learning alot about building engines and I think it wouldnt be that hard if I just had some practice. so once i got my original engine out I think im gonna play with it , take it apart, put it back together. I guess I could just try and put forged internals in my stock block myself, but do you guys think it would be better in the long run to buy one of stronger material than stock aluminum block? I see in magazines where there selling short and longblocks in iron and aluminum and the aluminum ones are always more expensive. this must be because there lighter in weight but are they as durable for a supercharged application as an iron block? and lastly, Who makes a great block for the money and what im looking for?
Old 10-07-2009, 06:13 PM   #7
BruceH
2008 Ford Mustang
BruceH's Avatar
Vehicle: 2008 Mustang GT/CS
Quote:
The aluminum block is stronger. I'd suggest you start researching via google on problem companies first. I won't mention those with a bad rep but they will pop out.
I'm in the process of getting everything together to forge my motor. I came up with www.livernoismotorsports.com www.fordracing.com or www.haneymotorsport.com as candidates for a prebuilt shortblock but decided to do it the old fashioned way by pulling the motor and taking it to a machine shop.
__________________
2008 GT/CS 5 Speed
Control Arms, Prothane MM's
Aluminum DS, McLeod RST/Fidanza FW
FRPP Ceramic Shorties
FRPP Whipple HO
Built Motor
Whipple Crew
BruceH is offline   Reply With Quote
2006, 46l, bill, block, bottom, buy, end, ford, forged, forging, gt, install, mustang, quotes, short, shortblock
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
