water in oil catch can :(
I installed at procharger kit and at the same time i installed an oil catch can. This thing fills up with water. Every 500 miles i check it and its almost full. The oil has no water and the radiator fluid has no oil so i don't think its a head gasket. Is this normal? The oil fill cap on the pass valve cover gets like a chocolate milkshake when the catch can gets full but when i check the oil its clean. Any thoughts on this would help. Thanks.
Do you have any pics of this? How many miles on your engine? How is it running? Seems like you have a breach somewhere and the water/antifreeze is being captured in the can.
What's the air temperature / humidity where you are at? Did it just start doing this or has it always done it? (time of year sensitive?)
With cooler weather, there will be a lot more condensation in the crankcase when the engine is cold. If you look inside (open up the oil fill cap) and look inside, it may look like baby-**** yellow, something like this:
that would be bad, but is caused/solvable with proper crankcase ventillation.
Since you are getting a lot of water in your can, it could be a lot of condensation getting collected and removed. If you're not loosing coolant, that's probably your cause.
jwog666
12-27-2021 08:09 PM
