Is a 62mm Twin Throttle Body worth it?
Old 02-05-2012, 10:26 PM
cboisits
cboisits's Avatar
Default Is a 62mm Twin Throttle Body worth it?
I've been doing my research and it seems that purchasing a 62mm twin throttle body (BBK, or my preference...FORD) is more worth it if you are forced induction. I only have a K&N CAI w/tune. Am I going to waste my money? If I could afford it, I'd have a supercharger under my hood but I have to be realistic. I am also looking into the STEEDA spacer. What do you guys think?
cboisits is offline
Old 02-05-2012, 10:52 PM
JCON
JCON's Avatar
Unless you're forced induction, I would spend your money elsewhere. Your looking at most at a 5rwhp gain.
If you want a throttlebody for looks and a slight bump in response but won't cost a ton you could buy a ported and polished throttlebody from Jerry Strannigan. Flow bench tested at 13% more air flow and it looks better than stock. Doesn't require a tune and when you send him your throttlebody as a core unit you can get it for $75. Also there have been some noted problems with BBK motors failing.
My Stock TB
ported and polished
Installed
JCON is offline
Old 02-06-2012, 08:12 AM
09BlueDevil
09BlueDevil's Avatar
I have a BBK tb in my car and honestly, when my only mods were CAI, TB, and exhaust, the biggest change was the sound not performance. But if you're planning on doing FI or cams or anything along those lines, it'll make the most out of those mods. Also, if you do go with the BBK TB, the spacer won't fit. the flaps for the inlet ducts on the TB will hit it and not open all the way.
09BlueDevil is offline
Old 02-06-2012, 08:38 AM
cboisits
cboisits's Avatar
Thanks for the feedback guys. Much appreciated.
cboisits is offline
Old 02-06-2012, 11:57 AM
Diabolical!
Diabolical!'s Avatar
No.
And take the Steeda spacer off of your list of future mods as well. It's a paper weight.
Diabolical! is offline
Old 02-06-2012, 05:17 PM
Nuke
Nuke's Avatar
No, not without a lot of other supporting mods.
And if you even BUY a spacer, let alone install one, we'll take your man card...
Nuke is offline
Old 02-06-2012, 09:18 PM
JCON
JCON's Avatar
I have ninja assassins outside his garage waiting for him to move it near the engine bay... Just say the word.
JCON is offline
piotrek53
10-13-2015 06:54 PM
JDWalton
09-24-2015 08:47 PM
TorinoCobra070
SVT Forums
09-18-2015 10:34 AM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: Is a 62mm Twin Throttle Body worth it?
