what would it take to get to 325 at the wheels?
Old 06-23-2006, 02:41 AM
randy78045
randy78045's Avatar
Default RE: what would it take to get to 325 at the wheels?
ORIGINAL: kickasp
well id prefer it be all motor, i cant afford to refill after every light lol.
with a good head, cam, intake, headers, full exhaust, and tb spacer you think it would be close to 300rwhp?
Finally someone thinks like me... kinda... just thinkin you will reach your goal quicker an cheaper with a s/c..... [sm=alcoholic.gif]
randy78045 is offline
Old 06-23-2006, 02:42 AM
silver91gt
silver91gt's Avatar
easily,
silver91gt is offline
Old 06-23-2006, 02:54 AM
kickasp
kickasp's Avatar
are you sayin a s/c would be cheaper than doin the h/c/i? i didnt think h/c/i was going to be that expensive???
i also wanna keep it on 87 pump gas*** that prolly makes it a little harder
kickasp is offline
Old 06-23-2006, 02:57 AM
silver91gt
silver91gt's Avatar
heads- 1000-1500
cam- 200-350
intake 350-750
but you need all the supporting mods too like injectors, exhaust, stuff like that.
Old 06-23-2006, 03:03 AM
randy78045
randy78045's Avatar
an what does a little boost cost???
Old 06-23-2006, 03:33 AM
boss429
boss429's Avatar
i just like to think theres a little more dignity in natural aspiration.
boost almost seems too easy, like cheating lol.
but when im done all my N/A mods im definitely going turbo
boss429 is offline
Old 06-23-2006, 03:56 PM
88stangaruu
88stangaruu's Avatar
Fully Ported Iron GT-40P's Heads are about $600 out of the paper and you can port them yourself, if you have the mechanical ability to
build an engine yourself, you should easily be able to just go over the intake ports yourself.
Trick Flow Stage 1 cam Trick flow cams are very nice pieces, work very well, they are dual pattern cams the specs on the stage I are; 221/225 @ .050 and .499/.510 lift
BBK Long tubes with o/r H-pipe together they are about $650, you can probably find them cheaper in the paper or on Ebay
70mm TB (little better throttle response) Look on Ebay, you can find BBK and Edelbroke pieces for around $150 or so, new they cost a little over $200
70mm EGR (or just delete it all together) Its cheaper to delete the EGR all together, you may need to take your computer to get it re-programed to eliminate the timing advance programed into it to prevent detonation. I just took mine off and i had no pinging, some have it, some dont. Its still a good idea to have the computer fixed though.
Gasket matched Edelbrock rpm intake I think this intake is about $550-$600 brand new, they're very good quality, very nice ports, etc. I got the cheaper edelbrock RPM knock off, Typhoon, it was like $350 but i had to port it out just to flow slightly better than an out of the box RPM
24# or 30# injectors 30#'s are a little big for a bolt on N/A 302 or 306, 24#'s work nice for a bolt on 5.0 motor. I have the motorsports 24#'s and i love them, i actually run a slight bit rich with them.
Hi-6 ignition box with fireball coil Upgraded engines need up-graded ignition systems. The stock dizzy is fine, you only need a billet dizzy if your pushing like 550 or more, then your going to need a new block and bottom end anyhow. But stock dizzy is perfect, replace the cap and rotor though. The Hi-6 is digital ignition, it has a rev limiter without using the little plugs like MSD, very nice ignition. Its around $225 new, look on ebay, you can definatly get a better deal there.
Walbro 255 Fuel Pump Just to keep up with the mods. 255 is the way to go with a 5.0
Smog delete, A/C delete Dont just get the pullies, get the eliminator plate from Trick Flow for like $25 and it re-mounts your tensioner arm where the A/C used to be, then just take the smog pump off and get a smaller belt.
Those are some really good components and work well, it should put you around 300-325 at the rear wheels, many of my friends are running that same, very basic set up and they are easily putting down around 300-325, with a little messaging maybe a tad bit more. Horsepower is all in the details. Dont cut corners, it will bit you in the *** in the long run. Good luck.
88stangaruu is offline
Old 06-23-2006, 04:02 PM
88BlueGT
88BlueGT's Avatar
You can get a Novi 1000 w/ a upgraded crank pulley and make approx. 10psi. Total cost would be about 2K for the blower and pulley, 200 for injectors (used), and 200 for maf.
$2,400 for 10psi?? How could you go wrong there!
88BlueGT is offline
Old 06-23-2006, 04:10 PM
w8less
w8less's Avatar
347 custom cam afr 185's edelbrock rpm 2 and supporting 70mm tb and supporting mods and u should be there.
that or look at my set up and some afr 185s later on down the road and i should be at 325+ on motor
w8less is offline
Old 06-23-2006, 04:52 PM
gspfunk
gspfunk's Avatar
ORIGINAL: duslep
im wonderin the same thing because here are my upgrades i just purchased and was wondering how much horse theyd put out.
1. BBK 75MM THROTTLE BODY
2. BBK 75MM EGR PLATE --1 & 2 are too big for a N/A motor, much less w/ E7's...probably hurting your power. 65, maybe 70 would be better
3. BBK Shorty Headers
4. BBK Off road H-pipe with no cats
5. BBK FUEL PUMP 255 LITERS/HOUR
6. Ford racing 30 lb injectors --WAY too much injector for your combo...24's are plenty and you'd probably have been okay w/ your 19's.
7. BBK SSI Intake (honed out)
8. Ford Racing Aluminum Driveshaft
9. A/C eliminator
10. Smog pump eliminator
11. Ford Racing 3.90 gears
12. MSD 6Al Ignition Kit
13. MSD Blaster 2 Coil
14. MSD 8.5 MM wires
15. NGK spark plugs
16. MSD Distributor
17. King Cobra clutch
18. Rebuilt t-5 tranny world class
19. Pro 5.0 shifter
20. Steeda clutch cable
21. Hypereutectic Flat Top .30 pistons
22. lunati camshaft with Duration 284/292, Lift .500/.510
23. Hi flo oil pump --Be careful w/ this...many horror stories about hi vol oil pumps....
Block is bored .30 over and has stock crank
Heads are also ported, but stock
kickasp--You will need all the bolt ons, a good H/C/I combo, and upgraded fuel components. You would attain that goal a little more easily w/ a 331 or 347 stroker....
gspfunk is offline
jwog666
12-27-2021 08:09 PM
UrS4
10-03-2015 06:23 AM
mungodrums
09-28-2015 10:54 PM
folivier
09-26-2015 02:28 PM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: what would it take to get to 325 at the wheels?
