it's best to buy a aluminum pan that has the boss for the sending unit....the fluid in the pan wouldn't give you the real temp of the trans but will get you close
so just taping a hole in the tranny pan will give me an close to accurate reading? thats all im worried about ......i would just drain the fluid, remove the pan and tap a hole then clean the shavings, replace pan and fill up with tranny fluid right??
you could use the drain plug hole if it has one..or like you said but will need a nut on the inside of the pan to keep leaks at bay...just lack weld it then use some expoxy
