Swapped transmission and driveshaft, bad vibrations...
Old 06-16-2007, 05:31 AM
Jfsram
Jfsram's Avatar
Default RE: Swapped transmission and driveshaft, bad vibrations...
I don't understand why a 2" drop would have driveshaft rubbing on things.
Why are you so focused on the driveshaft?
It could be pinion angle, pinion bearing, wheels/tires.
Jfsram is offline
Old 06-16-2007, 02:17 PM
74Grabber
74Grabber's Avatar
ORIGINAL: Jfsram
Because I have drove the last 50,000 miles with the same wheels, lowering springs,pinion angle, and everything else without a problem. The car was smooth as canbe before changing out the driveshaft and transmission.So it has to be the driveshaft or something related to it. When driving the car, it is obviously something to do with the driveshaft. When I can see the shifter vibrateing, I don't think that has to do with a wheel or tire.
74Grabber is offline
Old 06-16-2007, 02:22 PM
mattdel
mattdel's Avatar
something in the trans is bad, thats my guess.
output shaft bearing maybe
mattdel is offline
Old 06-16-2007, 04:11 PM
Blckstng93
Blckstng93's Avatar
Check the trans mount to.
Blckstng93 is offline
Old 06-16-2007, 04:37 PM
Matt Paul
Matt Paul's Avatar
Did you use a dail indicator and indexyor bell houseing to the trans and block?You should be with in .010-.005 thousands of an inch.If not theres youproblem.You said it yourself differnt year cars with major changes to them.
Thanks Matt
Matt Paul is offline
mtgldr
02-03-2024 09:00 PM
Galactic
04-29-2019 02:56 PM
Luke9222
10-22-2015 11:55 PM
vintageaion
09-08-2015 10:45 AM
Quick Reply: Swapped transmission and driveshaft, bad vibrations...
