1996 Ford Explorer 5.0 Motor
Old 06-21-2007, 09:54 PM
Justin_R
Justin_R's Avatar
Default 1996 Ford Explorer 5.0 Motor
I am looking at a stang with a 96 ford explorer motorjust wondering if there was any know issues with them? but hes rebuilt it and has the following mods:E303 Cam, Cloyes Double Roller Timing Chain, Pro M 70mm Throttle Body, 90mm Mass Air Flow, Fresh Air kit, MSD Ign, Mac Headers and H pipe, 2.5” Flow Masters.
Justin_R is offline
Old 06-21-2007, 10:26 PM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: 1995 Ford Explorer 5.0 Motor
95 explorers didnt have a 5.0 engine, and the 96-97.5's ddint have GT-40P heads either.
perhaps you should carefully double check what the engine truely is before you buy it
AdderMk2 is offline
Old 06-21-2007, 10:29 PM
Justin_R
Justin_R's Avatar
Sorry its a 1996 Ford Explorer motor, and I think GT40p is the engine code or whatever isnt it?
Justin_R is offline
Old 06-21-2007, 10:35 PM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: Justin_R
again... no.
GT-40P HEADS were not used until the later half of 1997 until 2000-2001
when you go to look at the car, inspect the passenger side head, lower right corner, near the head bolt.
It should say either GT or GTP
GT would be GT-40 heads. If these are stock GT-40 explorer heads, the motor is likely running lower compression. they usually have a larger (66cc) combustion chamber resulting in a 8.8:1 compression ratio.
GTP would be GT-40P heads. those are the ones that require special headers due to the spark plug angle
AdderMk2 is offline
Old 06-21-2007, 11:18 PM
Justin_R
Justin_R's Avatar
Alright sure will, so you have to have a custom set of headers to make it work like normal bolt on longtubes wont do the trick?
Justin_R is offline
Old 06-21-2007, 11:24 PM
AdderMk2
Banned
AdderMk2's Avatar
not custom headers... just P specific ones.
AdderMk2 is offline
Old 06-21-2007, 11:34 PM
Justin_R
Justin_R's Avatar
Oh gotcha.
Justin_R is offline
waid302
09-14-2015 11:19 AM
Stilz
08-19-2015 06:17 AM
Stilz
08-18-2015 09:40 AM
05slpGT
08-12-2015 02:32 PM
Redneck1465
08-08-2015 10:39 PM
Quick Reply: 1996 Ford Explorer 5.0 Motor
