I'm taking the distributor apart..
Old 07-29-2007, 09:31 PM
itsa87
itsa87's Avatar
Default I'm taking the distributor apart..
And cannot seem to figure out how, I just got my ignition pickup coil and am trying to get it in..
Anyone know how I can do this? I have a motorcraft distributor.
itsa87 is offline
Old 07-29-2007, 09:38 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: I'm taking the distributor apart..
There is a roll pin that goes thru the gear/shaft. You have to take that out then the gear has to be pressed off. Then the shaft slides up out of the housing. You will need a gear puller to get it off the shaft and you have to be carefull not to fukk it up.
PRO50SC is offline
Old 07-29-2007, 09:47 PM
itsa87
itsa87's Avatar
How do you get the roll pin out...Just push something through and it slides out?
And how much would the gear puller gear cost.
Thanks a ton.
itsa87 is offline
Old 07-29-2007, 09:57 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
You need a pin punch and a hammer to drive it out. It's in there tight. You maybe able to rent a puller from autozone or the like.
PRO50SC is offline
Old 07-29-2007, 10:02 PM
itsa87
itsa87's Avatar
Alright, thanks a ton...
That was a big help and good to know.
itsa87 is offline
Old 07-29-2007, 10:06 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Anytime, g/l!
PRO50SC is offline
uedlose
The Racers Bench
10-01-2015 08:31 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
mrappe
09-26-2015 10:16 AM
dalehunter
09-25-2015 10:51 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: I'm taking the distributor apart..
