NEW HEADS OR NOT
Old 08-30-2007, 07:45 PM
  #21
notchbackmatt87
notchbackmatt87's Avatar
Default RE: NEW HEADS OR NOT
my freinds got stock e7s that flow just as good as afrs all depends on the port work. and what your looking for i got mine done why cause i wanted a cam and i got some good port work im going to run my ported with bigger valves e7s with a 303 and scorpion rockers with a 100 shot ill be happy
notchbackmatt87 is offline
Old 08-30-2007, 08:10 PM
  #22
nitrous_bob
nitrous_bob's Avatar
are they 40's or p40's ?
regular 40's use any header, p's are a little diferent though
nitrous_bob is offline
Old 08-31-2007, 05:25 PM
  #23
89bulletlx
89bulletlx's Avatar
they are p40 heads . ive never heard e7s being worth a s*** . the guy at the head shop said its not woth the time or money. plus the will never flow like afrs
89bulletlx is offline
Old 08-31-2007, 06:39 PM
  #24
88ttops
88ttops's Avatar
Go with the AFR's the FRPP GT40 head use 20 year old technology and dont flow nearly as well as the AFR's. Spend the money get the good head and remember its not always the cfm it is th design and velosity of the port and the shape of the chamber.. If you really want to flow go with the Trick flow because when you step up the make big numbers when ported.
88ttops is offline
Old 09-01-2007, 01:11 AM
  #25
gspfunk
gspfunk's Avatar
Check out Tom Moss's site (tmossporting.com ??) if you want some real world #'s/info about ported E7's. You CAN make them flow well, but, like previously mentioned, the work is absolutely not worth it. There is a dyno graph on the site that shows 292 rwhp w/ the heavily worked E7's...that's a great #, but you could get that w/ little or no work w/ AFR's or another aftermarket head. Unless you want to spend a decent chunk of $$, you'll never see near that 292 hp at the wheels w/ E7's.
gspfunk is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
mustangheaven
10-07-2015 10:23 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: NEW HEADS OR NOT
