Serpentine belt trying to slide off of water pump?
Old 01-07-2008, 04:27 PM
1985stang
1985stang's Avatar
Default Serpentine belt trying to slide off of water pump?
I've been having a strange problem with my serp. belt. I just deleted the smog, and got a shorter belt (Gates). I routed the belt so it goes from the alt. straight down to the crank, then up around the water pump pulley, over to the p/s then back again. The belt has been riding towards the front of the car and it's even slowly wearing out that edge of the belt from itriding on the lip of the pulley. What can i do to stop this? The belt lines up into the grooves in all the pullies, and the tensioner is working. It's like the p/s pulley is not quite lined up with the water pump pulley.
1985stang is offline
Old 01-07-2008, 04:29 PM
Scout2232
Scout2232's Avatar
Default RE: Serpentine belt trying to slide off of water pump?
I took some washers and put them on the inside of my water pump pulley to space it out further, I had the same problem as you.
Scout2232 is offline
Old 01-07-2008, 05:19 PM
1985stang
1985stang's Avatar
Ok, that's a good idea. How many washers did you use?
jwog666
12-27-2021 08:09 PM
jerrytubes
10-23-2015 12:11 PM
Bokeo
10-10-2015 08:28 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: Serpentine belt trying to slide off of water pump?
