wat else can i put with little$$ ???
Old 02-09-2008, 03:26 PM
freddys5.0
freddys5.0's Avatar
Default wat else can i put with little$$ ???
hi i am new here and i just wanted to know wat else would be smart to put on my 89 gt. i dont know wat combo goes with wat for example if i putt a 80 mm maf, will i have to get a aftermarket fuelpump or bigger injectors?? i have on my stang the bbk pulleys electric fan, msd ignition, wires, coil, bbk off road h pipe with flowmasters, bbk cold air intake, bbk 70mm throttle body and spacer, and the centerforce clutch, wat else do u guys recommend i go with next? thanks in advance
freddys5.0 is offline
Old 02-09-2008, 03:31 PM
benz5800
benz5800's Avatar
Default RE: wat else can i put with little$$ ???
with all those upgrades pumping all that air into the car you need to balance it out with fuel. you better start looking to upgrade you fuel system. it wont make you any faster but it will keep you from having problems down the road
benz5800 is offline
Old 02-09-2008, 03:36 PM
w8less
w8less's Avatar
naw the 19's willl be fine. i would do gears and suspension
w8less is offline
Old 02-09-2008, 03:48 PM
freddys5.0
freddys5.0's Avatar
ok i was thinking that too, but im looking into getting more horsepower for my buck? i know suspension has alot to do with it cause if you cant keep em on the ground then wats the use right? but would u guys suggest like a bigger maf and an intake manifold or wat do u guys think????
Old 02-09-2008, 04:23 PM
WhiteWindsor
WhiteWindsor's Avatar
ORIGINAL: Jasperstang308
Absolutely. The 19's will be good till around 280-300 hp. Untill you get h/c/i, the stock one's are good. Gears and suspension would be at the top of the list untill you decide to rod that engine.
WhiteWindsor is offline
Old 02-11-2008, 08:58 PM
freddys5.0
freddys5.0's Avatar
h/c/i???
Old 02-11-2008, 09:31 PM
haromaster87
haromaster87's Avatar
Heads/cam/intake. The main way to see major hp gains without force induction or nitrous.
haromaster87 is offline
Old 02-11-2008, 09:32 PM
bighungrymatt
bighungrymatt's Avatar
heads/cam/intake
I also agree, upgrade gears and suspension next
bighungrymatt is offline
Old 02-11-2008, 10:03 PM
302army187
302army187's Avatar
+1 on gears
go with 3.73's or 4.10's
im going to 4.10's
302army187 is offline
Old 02-11-2008, 10:45 PM
BLK89GT
BLK89GT's Avatar
so far i think the best bang for the buck is a set of 3.73's
BLK89GT is offline
1996cobraconvertible
SVT Forums
13
01-07-2016 04:50 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
bconboy
09-24-2015 01:55 PM
Sminemann
09-17-2015 09:24 AM
LivingInThePast
09-16-2015 12:20 PM
Quick Reply: wat else can i put with little$$ ???
