Tire Rub Problem
Old 03-28-2008, 02:02 PM
87Stallion
87Stallion's Avatar
Default Tire Rub Problem
Here's my issue. I have 255/60/15's on 15x8 Draglite wheels on the rear. The right rear rubs the quad really bad. The left rear doesn't rub at all.
When I got the car it have 2 inches cut out of the stock rear springs. I just put new stock rear springs on hoping that raising it back up might help. But it still rubs on the RR.
My question is what could be causing just the one side to rub. I know I can remove the quads but I don't want to have to do that due to wheel hop.
I am at my wits end on this problem. Any ideas? Could the rearend have shifted some?
87Stallion is offline
Old 03-28-2008, 02:03 PM
87Stallion
87Stallion's Avatar
Default RE: Tire Rub Problem
bump
Old 03-28-2008, 02:17 PM
nseoi
nseoi's Avatar
wheel spacer is a cheap quick fix
nseoi is offline
Old 03-28-2008, 02:26 PM
AdderMk2
Banned
AdderMk2's Avatar
get tires that are the right size...
AdderMk2 is offline
Old 03-28-2008, 02:36 PM
nitrous_bob
nitrous_bob's Avatar
just end for end the quad.....it'll get you extra 1/2" and you can keep them that way
nitrous_bob is offline
Old 03-28-2008, 02:55 PM
87Stallion
87Stallion's Avatar
What do you mean by just end for end the quad? Turn them around. And as for the tire size 255/60 /15's aren't too big. Guys are running 275/60's with no rubbing issue.
Old 03-28-2008, 03:40 PM
anthros
anthros's Avatar
275's require that the quads be removed, 255 are getting there. you have 2 optios, one, remove the quad shocks and do your upper/lower control arms to eliminate whell hop. two, flip the quad shocks so that there facing the other direction, it gives you a little more clearance.
anthros is offline
Old 03-28-2008, 03:52 PM
CantStopTheFox...
CantStopTheFox...'s Avatar
I was always told that you can pull the quads after you install a good set of control arms...
CantStopTheFox... is offline
musnicki
09-23-2015 07:11 AM
MustangVixenGT
09-16-2015 04:16 PM
5.0 kevo
09-03-2015 06:24 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Tire Rub Problem
