clunk noise while driving
Old 04-12-2013, 08:33 PM
  #21
Maxwelhse
Maxwelhse's Avatar
Originally Posted by CW
Since this thread is back i'll post some things I have run into over the years that have caused similar noises.
u-joints worn or incorrect ones installed, bad trans mount causing front of driveshaft to rub the tunnel on the floor, Wheel weights on inner edge of front wheels rubbing front calipers, and most recently just this week on the 84 I picked up all four bolts holding the drive shaft to the rear diff were loose and backing out.
Glad I caught that one when I did.
I'll follow that up with a dose of loose yoke on pinion!!! (ask me how I know!!!)
Maxwelhse is offline
Old 04-12-2013, 08:40 PM
  #22
CW
CW's Avatar
Haha I knew I forgot one.
Had a brand new gear set and carrier go in the scrap bin because of that once. Damn shop reused the old pinion nut.
CW is offline
Old 04-12-2013, 08:49 PM
  #23
Maxwelhse
Maxwelhse's Avatar
I jacked my car up to replace the exhaust and repaint the under carriage and saw a BIG sling of oil/grease around the yoke on the under body and was like "WTF"???
I went to replace the pinion seal and discovered that nut was finger tight!!! I replaced the seal and tightened the yoke down, but ever since then the rear has whined a little... it whines ALOT on down shifts.. Oh well.. Crap-tastic 2.73s are dumpster fodder anyhow!
edit #3 (2 whiskey caused... #3 I forgot): When I reinstalled the nut, I had it dripping with loc-tite red, peened the snot out of 2 sides of it and rolled the threads over just in front of it... She ain't coming off accidentally next time!
Old 04-13-2013, 09:04 AM
  #24
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
that's because you did it wrong, the proper way to replace the seal is install a new crush collar and reset the preload on pinion, otherwise it's just a guess where you set preload, to tight and it'll burn the bearings up, to loose and it'll make noise
mjr46 is offline
Nick Oliver
10-17-2018 04:22 AM
bjdutch2005
03-24-2017 03:38 AM
StalkerGT
09-25-2015 02:41 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: clunk noise while driving
