cam removal issues
Old 07-14-2008, 06:26 PM
silentvoice19
silentvoice19's Avatar
Default cam removal issues
Ok ive removed what i tihnk is about everything. Can someone provied a link with pics because its not comming out and i have to be missing something. BTW its a 351w
silentvoice19 is offline
Old 07-14-2008, 06:28 PM
stanguy306
stanguy306's Avatar
Default RE: cam removal issues
Take your timing chain gear put it back on the cam thread in bolt finger tight and use the gear for leverage to pull and stear....pull out very slow....watching cam bearings.....just go slow...lol
stanguy306 is offline
Old 07-14-2008, 06:32 PM
1991LX5.0
1991LX5.0's Avatar
should just slide right out as long as the timing chain is off. You did remember to take out the lifters right?
1991LX5.0 is offline
Old 07-14-2008, 08:03 PM
silentvoice19
yup there out. It seems to feel like its getting caught i dunno man
Old 07-14-2008, 08:29 PM
steel1
steel1's Avatar
Iused a 5 inch bolt thatthreaded into the cam, used it for removal and install. Did you remove the thrust plate? Just a thought.
steel1 is offline
Old 07-14-2008, 08:33 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I use a 3/8 piece of thread rod about 12 inches lond and when pulling a cam since lobes are offset you have to carefully wiggle it and rotate it past journals
mjr46 is offline
Old 07-14-2008, 08:50 PM
silentvoice19
lol this sucks does the motor have to be at tdc plus anyone have any good ideas on how to loosen up a seized motor?
Old 07-14-2008, 09:00 PM
mjr46
mjr46's Avatar
pull the motor out.... if its siezed and undo all rod caps and smack the pistons from the underside with a extention and mallet
mjr46 is offline
Old 07-14-2008, 09:31 PM
silentvoice19
yea im gonna have to the motor is already out btw.
Luke9222
10-22-2015 11:55 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
vintageaion
09-08-2015 10:45 AM
zanemoseley
09-06-2015 12:58 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: cam removal issues
