Orifice (hehe) tube question!
Old 10-10-2008, 01:07 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Here ya go. I just looked up the procedure on Alldata here at work. The o-tube is part of one of the lines. Here's the right up
Do not attempt to remove the fixed orifice tube. The fixed orifice tube is an integral part of the liquid line. When a new fixed orifice tube is required, a new liquid line must be installed.
However, an orifice tube replacement kit may be used instead of replacing the tube and line assembly.
Line & Tube Assembly Replacement
1. Discharge refrigerant from system.
2. Disconnect refrigerant line at condenser outlet connection.
3. Disconnect refrigerant line at the tube-O end using a wrench on each side of tube-O fittings and remove line from vehicle.
4. Route new refrigerant line, and integral fixed orifice tube, with the protective caps installed.
5. Remove protective caps and connect new refrigerant line into the system using new O-rings lubricated with refrigerant oil.
6. Leak test, evacuate and charge refrigerant system.
Orifice Tube Replacement
1. Remove refrigerant line from vehicle as described under ``Line & Tube Assembly Replacement.''
2. Identify location of orifice tube by three indented notches or a circular depression on metal portion of tube.
3. Note angular position of ends of liquid line for assembly reference.
4. Cut a 2.5 inch section from tube at orifice tube location. Do not cut any closer than one inch from start of bend in tube.
5. Flush out two lengths of refrigerant line to remove any contaminants.
6. Lubricate O-rings with clean refrigerant oil, then assemble orifice tube kit to line. Ensure flow direction arrow points toward evaporator end of line and taper of compression rings is toward compression nut. When properly assembled, the inlet tube is positioned against the orifice tube tabs.
7. With tube hex nut secured in a vise, torque compression nuts to 65-70 ft. lbs.
8. Install liquid line using new lubricated O-rings.
9. Leak test, evacuate and charge refrigerant system.
PRO50SC is offline
Old 10-10-2008, 01:12 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
You can get the tools from advanced or a similar store.
http://www.toolfetch.com/Brand/OTC/A...connect_Tools/
PRO50SC is offline
Old 10-10-2008, 04:40 PM
Project 5.GO!
Project 5.GO!'s Avatar
Hey, thanks for the great write-up! Good info, and it seems pretty straight-forward. One last thing, can you point me to the right line and tube? LOL! Sounds like a dumb-*** question, I know. I know it connects to the black cylinder at the back of the engine bay on the passenger side, but where does it end?
Project 5.GO! is offline
Old 10-10-2008, 05:31 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
It should be the small diameter line running between the condenser and the accumulator.
PRO50SC is offline
Old 10-10-2008, 05:34 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
lol alldata for the pro's!!!!
mjr46 is offline
Old 10-10-2008, 06:35 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Uhh huh, yeah, dats right
PRO50SC is offline
Old 10-13-2008, 08:37 AM
Project 5.GO!
Ok, so the black cylinder in the back of the engine bay is what, the accumulator? It looks like it accumulates, so I'm going to guess the little radiator-looking thing in the front is the condenser?
Man, that's an awkward feeling when you don't know what you're talking about! LOL!
Old 10-13-2008, 09:21 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Correct
PRO50SC is offline
Old 10-13-2008, 11:00 AM
Project 5.GO!
Holy Schitt! I got it right!
I'm going to dig into this one on Friday, and hope to be "chillin" on Saturday! Thanks for saving me at least 400 bucks, Pro50!
jwog666
12-27-2021 08:09 PM
Luke9222
10-22-2015 11:55 PM
chrisdbassplayer
10-13-2015 06:53 PM
treesloth
09-28-2015 07:03 AM
BrantleyS550
09-14-2015 04:18 PM
Quick Reply: Orifice (hehe) tube question!
