Oil in the throttle body
Old 11-01-2008, 09:38 PM
samseed101
samseed101's Avatar
Originally Posted by chath_brick
i've never heard of that happening before, could be a pretty serious problem
Unfortunately, this is kinda common but it's a cheap easy fix. Another joy on having a PCV system, lol. That's part of the reason I completely removed mine back before I ended up selling the car. Ran much better without the original PCV setup.
samseed101 is offline
Old 11-01-2008, 10:20 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Damn where have you been lately sam? Have you bought another stang yet?
projectresto83 is offline
Old 11-01-2008, 11:59 PM
samseed101
samseed101's Avatar
I've been around, but mostly lurking. And even then it's only once or twice a month. But I'm starting to feel the itch again, LoL. I'm giving some serious consideration to buying a 4.6 and slapping a turbo on it, or maybe getting another 5.0 and going turbo with that instead. I figured I had a blast with the S/C, nitrous, meth setup... why not try turbo. But not yet, lol.
Meanwhile, I'll probably start visiting more frequently and helping people out like I did before. I've gotta admit, I do miss my TwEECer. I loved fine tuning the spark and MAF manually
Old 11-02-2008, 12:48 AM
dudeboy
dudeboy's Avatar
Originally Posted by silver91gt
WELL, SINCE HE SAID ITS IN THE THROTTLE BODY IT ISNT FROM THE PCV! THE PCV GOES TO THE UNDERSIDE OF THE UPPER INTAKE.
THERES NOTHING WRONG WITH IT, IT IS NORMAL AND THERE IS NO NEED TO WORRY.
EVERYONE JUMPS TO A CONCLUSION THAT SOMETHING IS MESSED UP, AND ALL YOU NEED TO DO IS THINK ABOUT IT A LITTLE BIT.
This is 100% dead wrong!
The pcv can and will contaminate the intake, and if the problem is severe enough oil will literally drip from the TB down the inake tube.
This is a problem, and it is hurting performance.
No doubt the plugs are being fouled prematurely. There are other problems as well.
First thing to do is sort out WHERE the oil comes from.
A separator on the pcv line can help with this.
Check the vac/pressure on the crankcase, with and without the pcv attached.
Check the following for some background info...
http://www.freewebs.com/vristang/pcv...trolissues.htm
good luck,
jason
dudeboy is offline
Jb145700
08-21-2022 06:37 AM
GimpyHSHS
09-18-2015 12:27 PM
TorinoCobra070
SVT Forums
09-18-2015 10:34 AM
pimp2303
09-17-2015 08:45 PM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
Quick Reply: Oil in the throttle body
