fuel pump wiring question
So I've been looking on AllData to try to find my answers but its the dumbest thing ever.
I can find the "wiring diagram" for the fuel pump relay but I do not know where the wires come from or go. So, my questions are:
The pink wire with the black tracer that comes into the fuel pump relay power side has a fusible link, where the hell is that?
Does anyone know where G400, the ground for the fuel pump, actually grounds to?
When I was going through my fuel pump problem I traced my wiring harness ('93) from the passenger side firewall. It split to the MAF area for the pump relay and then to the solenoid where the fusible link is. If you already have the wiring diagram you should be able to peel back some of the convoluted tubing and find your link. Hope this helps!
Design1795
01-24-2017 10:38 PM
Design1795
08-24-2015 04:41 PM
jpplaw
08-22-2015 09:29 PM
