Distributor gear question
Old 02-03-2009, 10:50 PM
89mustangfive0
89mustangfive0's Avatar
Default Distributor gear question
im swappin out my b-303 cam for my anderson b-31 cam, does anyone know off-hand if i have to swap the distributor gear or a specific one i should use. thanks
89mustangfive0 is offline
Old 02-03-2009, 10:55 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if you had a roller cam in there previous with a stock oem distributor then you already have the steel gear on the dizzy and your fine
mjr46 is offline
Old 02-03-2009, 10:58 PM
89mustangfive0
ok cause i no they make bronze gears and i belive andersons cams are made of billet steal and wasnt sure if i had to change it
Old 02-03-2009, 11:14 PM
mjr46
mjr46's Avatar
I don't believe you need to swap them for such, bronze is softer and will require frequent checks for wear
mjr46 is offline
Old 02-03-2009, 11:18 PM
89mustangfive0
yea i fgured, i noticed they make billet steel gears also, im going to call anderson tomorrow just to be on the safe side
Luke9222
10-22-2015 11:55 PM
StalkerGT
09-25-2015 02:41 PM
Mustangmalo
09-06-2015 05:22 PM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Distributor gear question
