How to make the change to Mech. gauges?
Old 02-09-2009, 12:41 AM
Catchpole
Catchpole's Avatar
Default How to make the change to Mech. gauges?
What is involved in making the switch? I'm tired of my gauge showing a full tank for the first five minute of drive time and I always wonder about the fuel pressure, and power gauges.
Catchpole is offline
Old 02-09-2009, 02:02 AM
Chaoss84GT50
Chaoss84GT50's Avatar
All I can think of is getting the Mechanical sending units. Fuel Level wont be Mechanical though, that signal comes from the fuel level sending unit, I believe. Shouldnt be a hard swap though, just tracking down where all the original sending units are and replacing and running new lines.
Chaoss84GT50 is offline
Old 02-10-2009, 02:33 PM
j-wigg
j-wigg's Avatar
you had mentioned a mechanical sending unit. the part on summitracing.com Dorman 692-106, is that a mechanical? i am having a problem with a fuel gauge always showing full. i actually have it open on another thread but i dont think its the sending unit cuz when i disconnect the harness for the sending unit, the gauge still shows full.
j-wigg is offline
Old 02-10-2009, 06:41 PM
Chaoss84GT50
I replied to that other thread. I would think that your gauge itself is bad. I would get an Autometer electric fuel gauge and plus that bad boy in. No too hard from what I remember just some wires BUT you have to know what OHM range your fuel pump is. There is like 5 different style gauges that use diff OHM ranges. Other than that you should just be able to plug in and start your car. I would run 2 new wires all the way back to the sending unit from the gauge, so you know that the wires are good IMO.
Good luck
Old 02-10-2009, 06:42 PM
j-wigg
j-wigg's Avatar
is that a separate gauge thats going to have to sit in a pod?
j-wigg is offline
Old 02-10-2009, 06:45 PM
j-wigg
j-wigg's Avatar
the fuel pump is stock. from what i know. any idea of what ohm it is? (88 gt vert)
j-wigg is offline
Old 02-10-2009, 06:50 PM
Chaoss84GT50
Probably have to put the gauge in a pod. I dont know the OHM range for the stock fuel pump but im sure you could google it or look in a haynes/chiltons manual and it shoulld tell you how to test and replace it and the OHM range too.
Old 02-10-2009, 07:15 PM
j-wigg
j-wigg's Avatar
are the new instrument clusters with the 14mph gauge electric?? see. http://www.latemodelrestoration.com/...0%201&comp=LRS
would that work or no??
I appreciate ur time
j-wigg is offline
Old 02-10-2009, 07:19 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
correct the malfunctioning fuel gauge - either fuel gauge, sender or IVR OR anti slosh module if so equipped with one
mjr46 is offline
Old 02-10-2009, 09:48 PM
Chaoss84GT50
It looks to me like the fuel gauge is electric on that. Should work
drfister
05-03-2018 10:38 PM
Joolander
05-02-2016 02:28 AM
squishbang
12-04-2015 02:29 PM
unit91
08-21-2015 11:44 PM
jjwinel78
08-17-2015 03:34 PM
Quick Reply: How to make the change to Mech. gauges?
