Explorer Intake question
I was wondering what years explorers will the intake work? Also i have seen they come with i think 2 diff part numbers, is there a certain one i want? Anything else i need to change if i was to put on an explorer intake? Thanks in advance fellas, just tryin to learn all i can about it before i go get one.
There was two intakes, late 95-early 97 and 97-later. The early explorer intake has thicker flanges on the upper, has egr provisions for emissions, and has a boss in the #5 runner for the ACT, which will need to be drilled and tapped to a 3/8 NPT. Now the later explorer intake has thinner flanges on the upper, NO egr provisions, and doesn't have a boss in the #5 runner, you can tapp it, but there is less material to thread the sensor. Also, you'll need a elbow adapter for the upper.
i'm looking at a 98 explorer manifold. 24lb inj with fuel rails, 65m tb. will i be needing a bigger hood? this going on a 88 w/ no maf. do i need the maf if using the 24lb injectors? go with the stock 19 or 24? what do i have to do about the egr?(spacer)
Luke9222
10-22-2015 11:55 PM
