How is this ele. water pump!?!
I ordered the FRPP a/c delete kit n I'm removing my smog pump. My water pump is gone. So I figured I would do the ele. fan, ele. water pump, n 3g alt. swap.. I was lookin on ebay for ele. water pumps n came across this 1:
http://cgi.ebay.com/ebaymotors/Elect...mZ330320232028
Is that a good ele. water pump? pros n cons? I'm wondering why its sooo much cheaper then other brands!?!
Thanx
Thanx
never heard of them but the design looks good. Most like mizer stick the electric pump directly on the motor instead of on legs like this one which means you get a lot of conductive heat from the motor. As most know, electrical components and excessive heat don't mix.
What sucks about electric water pumps is you don't know when they go out unless you rig a light to tell you when it's not drawing current or there's no flow.
^^^^^^^sure you do, the temp will rise quick......asfor the above mentioned pump....= junk, cheap china mans pump.......I run a meziere with built in idler = no redoing belt config like you'll have to, and meziere is proven , yeah they aren't cheap but quality usually isn't
jwog666
12-27-2021 08:09 PM
