Can i use 1.7 RR with GT 40 heads and an E cam
Old 07-24-2009, 05:27 PM
stang8689
stang8689's Avatar
Default Can i use 1.7 RR with GT 40 heads and an E cam
Getting ready to put cast gt-40s on my 93 engine and it has an E cam has anyone used this set up with 1.7 roller rockers? I want to buy new roller rockers so if i can use 1.7's id rather get a little extra power
stang8689 is offline
Old 07-24-2009, 06:18 PM
AdderMk2
Banned
AdderMk2's Avatar
sure you can. you will definitly need to check PTV and get some decent springs
AdderMk2 is offline
Old 07-24-2009, 07:31 PM
stang8689
stang8689's Avatar
so i need to upgrade the valve springs which ones should i get
Old 07-24-2009, 09:09 PM
Bubba 95SN
Bubba 95SN's Avatar
E=.498 lift with 1.6 with 1.7 lift is .529 Math is this .498/1.6=311.25x1.7=.529
Bubba 95SN is offline
Old 07-25-2009, 06:50 AM
stang8689
stang8689's Avatar
Thanks just trying to get a game plan goin I want to make sure i wont have any ptv clearance issues hoping someone was running this set-up cause I would hate to buy the 1.7's and then not have enough clearance and be stuck with them
Old 07-25-2009, 08:38 AM
Joel5.0
Joel5.0's Avatar
Total valve lift has nothing to do with the possibility of PtV problems. Use FRPP M-6513-A50 single w/damper springs + retainers and locks or TFS springs upgrade kit, buy an adjustable pushrod and check for the correct PR length that setup will require by checking the geometry.
Joel5.0 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
kevsgt
10-09-2015 10:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Drastang
09-30-2015 03:48 AM
Quick Reply: Can i use 1.7 RR with GT 40 heads and an E cam
