Pro-comp Heads?
Pro-comp Heads?
i am looking to buy some heads for my 91 gt and ran across this company through jegs. I havent heqard much about them and wanted to find some people running them.Here are the specs i got off the site.
Procomp Aluminum Heads For Small Block Ford 210CC intake Runners And 60CC Combustion Cambers There Heads Are Ready To Bolt On with 3/8 Studs And Guide Plate The Springs are Good up to 600 Lift Solid Or hydraulic Cams
Aluminum Cylinder Heads Feature-
Hardened Seats
Bronze Valve Guides
High Grade Aluminum
Multi-Angle Seat Design
Available Complete or Bare
Available fully CNC Machined
Designed Performance Valve Springs
Advanced Port Design for Greater Flow
Combustion Chamber: 60cc
Intake Runner: 210cc
Intake Valve: 2.02"
Exhaust Valve: 1.60"
Spring Pressure Closed: 140 lbs. @ 1.800"
Spring Pressure Open: 325 lbs. @ 1.225"
Retainer Material: Steel
Valve Seal Material: Viton
Valve Guide Material: Manganese Bronze
Valve Job: 3-angle
Hardened Seats
Bronze Valve Guides
High Grade Aluminum
Intake Valve: 2.02"
Valve Job: 3-angle
Everything about them is cheap. Most will tell you not to touch them. Just keep looking. I have less than $650 in a set of Edelbrock RPM's with proper srings, setup, etc. There are deals, you just have to find them. FWIW I will be going Trickflow next. Good luck!!
i would love to go trickflow or edelbrock btu money is the only reason i asked about the pro comps. Thanks guys!
please read forum rules!!! do not make 2 identical threads ....ie one here and the other in gen disc, thank you.
