clutch issues
Old 03-24-2010, 10:28 PM
  #21
1killercoupe
1killercoupe's Avatar
You should check that cable for stretch to start with 1 more time if it checks out then you have a issue with the clutch ball stud or the fork and throwout bearing so you have to pull the transmission anyway. Check it out and you'll get it fixed
1killercoupe is offline
Old 03-26-2010, 08:23 AM
  #22
mattkoly
mattkoly's Avatar
Not hard to change bearing retainer if you have the transmission out. just have to unbolt and then bolt new one in.
mattkoly is offline
Old 03-26-2010, 10:53 AM
  #23
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Originally Posted by jssblues
so how difficult is it to install new bearing retainer??? i have read about having to use endplay shims cause the steel retainer will be different..
it's called preload and it's the shim that goes behing the race in the retainer, most just guess and transfer over he one in the stock set up, however I like to use a depth micrometer and do the math and select the proper shim from that, tremec's website has the instructions on how to properly do it.
mjr46 is offline
Old 03-26-2010, 01:26 PM
  #24
jssblues
jssblues's Avatar
finally got time to pull the tranny and my problem was just as i suspected...the pivot ball was backed out and on its last thread..needed new retainer and t.o. anyway .......
jssblues is offline
Old 03-26-2010, 01:53 PM
  #25
jssblues
jssblues's Avatar
the shaft on the retainer was wore down all to hell , just like everyone says thats what will happen to the stock aluminium ones..
jssblues is offline
AmericanMuscle4.6GT
11-10-2015 02:06 PM
ccdguy
09-19-2015 05:20 PM
PNYXPRESS
09-14-2015 09:50 PM
MasterLanMan
09-13-2015 08:21 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: clutch issues
