Intake+Cam vs. Heads
Old 08-06-2005, 05:30 PM
jonboy5.0
jonboy5.0's Avatar
Default Intake+Cam vs. Heads
Edelbrock Intake and cam, or Edelbrock heads? Finally saved up some money, and dont know which route to take. Pros, cons, and any advice in general appreciated.
jonboy5.0 is offline
Old 08-06-2005, 05:36 PM
wildstang87
wildstang87's Avatar
Default RE: Intake+Cam vs. Heads
i say go with the heads first, you wont notice much gain from the cam/intake with the stock heads, but you will notice a gain from the heads with the stock cam/intake.
wildstang87 is offline
Old 08-06-2005, 06:08 PM
jonboy5.0
jonboy5.0's Avatar
How much will I notice? Any time off the quarter mile?
Old 08-06-2005, 08:02 PM
wildstang87
if you go with some eddie performers you will easily get 20HP on a stock motor. that should shave some time off your 1/4, unless the extra power causes you to lose traction, but i doubt it. after doing that do the gears, cam, intake. that should wake the motor up.
Old 08-06-2005, 09:42 PM
vfast
I ♥ Acer
vfast's Avatar
I would do all 3 at once and add a new timing chain and gears.... the heads if match ported to the intake with a new can are looking at about 45-50hp
vfast is offline
Old 08-07-2005, 02:12 PM
jonboy5.0
jonboy5.0's Avatar
Would I be wasting money if I bought a new matching cam and intake, and just had my stock heads ported and polished?
Old 08-07-2005, 06:26 PM
jonboy5.0
jonboy5.0's Avatar
...Waiting for a reply...
Old 08-07-2005, 07:51 PM
Quik
Quik's Avatar
stock heads will need a few hundred in work. PP, valve job, guides cut, new springs, a good set of valves
Quik is offline
Old 08-07-2005, 08:10 PM
crazyhorse
crazyhorse's Avatar
i would go with a good set of aluminum heads that would fit future plans, and probably put the cam in too while i had the engine apart. good luck either way.
crazyhorse is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
Florida Regional Chapter
09-30-2015 08:04 PM
Drastang
09-30-2015 03:48 AM
Quick Reply: Intake+Cam vs. Heads
