Spark plugs jumping fire
Old 08-22-2016, 12:14 PM
  #31
95stang302HO
95stang302HO's Avatar
Originally Posted by 88 orangepeel notch
Just for giggles then, try adding another ground. From the block right to the frame.
Also, verify you still have a factory ground from the back of the engine. It grounds the head to the firewall. Also there's another ground for the computer in the passenger kick panel.
I went thru this type of problems a couple years with my car. Took me weeks of throwing wrenches before I found a bad ground. That's all it was. I didn't have arcing wires, but very erratic electrical issues.
Ok I'll try it. Instead of typing in Google ''plugs jumping fire'' i put in arcing instead and a lot more results came up. One comment said that it may be the Icm.
95stang302HO is offline
Old 08-24-2016, 09:30 AM
  #32
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if you can see spark arcing out of something, it's not rocket science my friend, right where the spark arcs out is the path often where the problem is...ie a ground or component
mjr46 is offline
Old 08-24-2016, 01:38 PM
  #33
95stang302HO
Well if you can figure it out props to you Mr ********. But i cant so quit being a dick
Old 08-25-2016, 06:44 AM
  #34
mjr46
mjr46's Avatar
wrong move........you should have listened, no one was being a dick, I was trying to lead the horse to water, but obviously he didn't want to drink it, so enjoy your time out. This thread is closed.
mjr46 is offline
BOB ROME
07-26-2023 01:54 PM
jwog666
12-27-2021 08:09 PM
Dathan
10-05-2015 05:52 AM
lmurf60
09-24-2015 10:07 PM
Quick Reply: Spark plugs jumping fire
