Quick Balancer question
Old 05-14-2011, 11:49 PM
Venomantidote95
Venomantidote95's Avatar
Thats the catch, if the bolt screws in enough just pull it on that way!
Venomantidote95 is offline
Old 05-15-2011, 10:35 AM
ryan_89_mustang
ryan_89_mustang's Avatar
Alright so I will try and pull it on with the bolt i suppose. I thought it was easier to pull the threads out of the crank than you guys are saying.
Also I asked originally about the little pointed cap thing that comes with the puller. It seems like that would damage the first few threads on the crank. Is it safe to stick that in the hole or should I put the bolt in the crank without the washer and use the puller against that?
ryan_89_mustang is offline
Old 05-15-2011, 11:09 AM
AdderMk2
Banned
AdderMk2's Avatar
I always put the bolt back in with no washer.
AdderMk2 is offline
Old 05-15-2011, 01:55 PM
Venomantidote95
The puller is made at the right angle where it dosent damage the threads, when you get the balancer off look in the recess for the bolt and you will see why they use a washer!
you cant have anything between teh puller and crank unless its a smaller diameter of the balancer inner flange or you will be pushing against the balancer thus never getting it to move!
tmdm
05-02-2021 02:49 PM
LivingInThePast
09-16-2015 12:20 PM
Big Al's 03
09-15-2015 09:05 AM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: Quick Balancer question
