Water in Headlights?
Old 06-04-2011, 05:03 PM
Hot Rokker
Hot Rokker's Avatar
Default Water in Headlights?
So, a while back I bought a new set of headlights, and recently everytime it rains water is getting into one of the main lamps and it looks like an aquarium afterward. I pretty much siphon the water out each time, it's getting annoying and I'm not sure what the problem is.
I've got the rubber stripping around it, but I'm either thinking that something is cracked or I haven't sealed it correctly? But if it's not sealed correctly, then how would it be in only one of the lamps?
Help?
Hot Rokker is offline
Old 06-04-2011, 06:13 PM
Boss_Hotrod
Boss_Hotrod's Avatar
The rubber seal doesnt seal the light. The lights are glued together. You can take and drill a small hole in the bottom of the light to drain the water or replace the light.
Boss_Hotrod is offline
Old 06-04-2011, 06:41 PM
1988TTOP
1988TTOP's Avatar
u get what u pay for man cheap lights leak
1988TTOP is offline
Old 06-04-2011, 07:09 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
drill a hole in the bottom is your cheap fix
mjr46 is offline
Old 06-04-2011, 11:35 PM
Hot Rokker
Hot Rokker's Avatar
They weren't exactly cheap.
Anyways, besides drilling the hole is it possible to find said leak and seal it with silicone or something?
I just don't wanna buy another headlight, I'm broke as it is. And I don't exactly want to drill a hole as I just want the water to stop coming in entirely.
Thanks for the help thus far, sorry for the pestering, I'll probably have more in the future. Teehee.
Old 06-05-2011, 05:12 AM
4rdnut
4rdnut's Avatar
take the lights back out and look at the seam joining the two halves, between the clear front and grey back, thats where it leaks. simple fix is to take a hot glue gun and put a bead of hot glue on the seam all the way around on both headlights, when the hot glue dries, it blends right in with the clear plastic and you can hardly notice it. The aftermarket headlight makers only spot glue the two halves together. my headlights would fog up after washing the car and i found it was the poorly glued seam letting the water in.
4rdnut is offline
Old 06-05-2011, 08:33 AM
9redfox3
9redfox3's Avatar
You need to seal them ..........
http://www.americanmuscle.com/mustan...ing-video.html
9redfox3 is offline
Old 06-05-2011, 02:58 PM
Hot Rokker
Hot Rokker's Avatar
Originally Posted by 9redfox3
Thank you so very much!
jwog666
12-27-2021 08:09 PM
jerrytubes
10-23-2015 12:11 PM
b8checker
10-08-2015 12:55 PM
Drastang
09-29-2015 03:31 PM
Quick Reply: Water in Headlights?
