Fox wont start, sometimes...
Old 04-25-2012, 07:36 PM
5l4life
5l4life's Avatar
Default Fox wont start, sometimes...
Hi guys i have an 88 lx that only starts sometimes. When i go to start the car when i turn the igition i hear a "click". I first thought it was a loose battery teriminal but its not. other things i have checked are the starter and solonide and wire from both and ground to the body and all are fine. Anyone have any suggestions what this might be? thanks.
5l4life is offline
Old 04-25-2012, 08:52 PM
nitrous_bob
nitrous_bob's Avatar
what do you mean the starter and selonoid are "fine" what checks did you use
and have you checked the inertia switch harness as well ?
nitrous_bob is offline
Old 04-26-2012, 10:14 AM
5l4life
5l4life's Avatar
starter and solonide are fairly new but i did take it back off and made sure it had power and ground and that the bendix was moving.
Inertia switch? is that the one in the trunk? no i have not checked that, but i will.
Someone mentiond to me it possably be an iginition switch or cylinder key, what do you think? thanks.
5l4life is offline
Old 04-26-2012, 01:02 PM
mattdel
mattdel's Avatar
bad connections (power/ground) to starter or starter is bad or battery is dead
mattdel is offline
Old 04-26-2012, 03:42 PM
1fast Lorinser
1fast Lorinser's Avatar
try adding a ground wire to your starter straight to your negative terminal on the battery. I just finished dealing with the same issue.
1fast Lorinser is offline
Old 04-26-2012, 05:52 PM
5l4life
5l4life's Avatar
Now this seems like it might work. believe me im ready to tear my hair out with this. So you mean to run my ground wire from my starter directly to the negative terminal?
5l4life is offline
Old 04-27-2012, 10:12 AM
1fast Lorinser
Yea what you can do to get a good and direct contact is take off the bottom bolt from the starter, the 1 with the easiest access and take a pretty decent size wire maybe 2guage thick wire put a circle connector on the wire and just bolt it between the starter bolt and the starter and run the other side straight to your negative terminal on the battery and make sure everything is nice and tight and try starting your fox multiple times so u know it starts everytime.
zsmart
Convertible Tech
02-29-2016 08:33 AM
1TUFF302
11-05-2015 04:02 PM
StalkerGT
09-25-2015 02:41 PM
vintageaion
09-08-2015 10:45 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Fox wont start, sometimes...
